Saltar al contenido principal
Pantech Breakout Micro SD/SIM Card Replacement
Qué necesitas
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: paso 1, imagen 1 de 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: paso 1, imagen 2 de 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: paso 1, imagen 3 de 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: paso 2, imagen 1 de 2 Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: paso 2, imagen 2 de 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: paso 3, imagen 1 de 2 Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: paso 3, imagen 2 de 2
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
Conclusión
3 personas más completaron esta guía.
Ryan Murphy
Miembro Desde 09/25/14
898 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 5-5, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 2,591
