Saltar al contenido principal
Pandigital Super Nova Screen Replacement
Qué necesitas
  1. Pandigital Super Nova Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Screen Replacement: paso 2, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 2, imagen 2 de 2
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Screen Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Screen Replacement: paso 4, imagen 1 de 1
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Screen Replacement: paso 5, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 5, imagen 2 de 2
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Screen Replacement, Front Facing Camera: paso 6, imagen 1 de 2 Pandigital Super Nova Screen Replacement, Front Facing Camera: paso 6, imagen 2 de 2
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Screen Replacement: paso 7, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
  8. Pandigital Super Nova Screen Replacement, Screen: paso 8, imagen 1 de 2 Pandigital Super Nova Screen Replacement, Screen: paso 8, imagen 2 de 2
    • Use a screwdriver to remove the six .15 mm screws that hold the motherboard in place. Set aside.
  9. Pandigital Super Nova Screen Replacement: paso 9, imagen 1 de 3 Pandigital Super Nova Screen Replacement: paso 9, imagen 2 de 3 Pandigital Super Nova Screen Replacement: paso 9, imagen 3 de 3
    • Remove the eleven screws that hold the screen to the base. Eight are .15 mm and three are .11 mm.
  10. Pandigital Super Nova Screen Replacement: paso 10, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 10, imagen 2 de 2
    • Remove the motherboard from the tablet using a nylon spudger.
    • A regular black nylon spudger should be used to avoid damaging the motherboard.
  11. Pandigital Super Nova Screen Replacement: paso 11, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 11, imagen 2 de 2
    Comprar
    • Use tweezers to carefully remove the connector between the screen to the tablet.
  12. Pandigital Super Nova Screen Replacement: paso 12, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 12, imagen 2 de 2
    • Use a pry tool to carefully separate the motherboard from the hard casing.
    • Excessive force in this step can damage your device.
  13. Pandigital Super Nova Screen Replacement: paso 13, imagen 1 de 1
    • Lift the motherboard out of the tablet.
    • Remove the second connector between the screen and the motherboard.
  14. Pandigital Super Nova Screen Replacement: paso 14, imagen 1 de 3 Pandigital Super Nova Screen Replacement: paso 14, imagen 2 de 3 Pandigital Super Nova Screen Replacement: paso 14, imagen 3 de 3
    • Pry the silver screen box from away from the device.
    • Open each of the four clips securing the screen box to open it.
  15. Pandigital Super Nova Screen Replacement: paso 15, imagen 1 de 2 Pandigital Super Nova Screen Replacement: paso 15, imagen 2 de 2
    • Lift the screen out of its protective box.
    • If the protective box is damaged, it will also need replacing.
Conclusión
2 personas más completaron esta guía.
sterling hannsz
Miembro Desde 10/10/16
267 Reputación
2 Guías creadas
Equipo
Texas Tech, Team 1-2, Bennett Fall 2016 Miembro de Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 260
