Saltar al contenido principal
Pandigital Super Nova Front Facing Camera Replacement
Qué necesitas
  1. Pandigital Super Nova Front Facing Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the screw covers from each corner of the back side of the device.
    • Set aside.
  2. Pandigital Super Nova Front Facing Camera Replacement: paso 2, imagen 1 de 2 Pandigital Super Nova Front Facing Camera Replacement: paso 2, imagen 2 de 2
    • Using a Philips screwdriver, remove all four .15 mm screws from each corner.
    • Set aside.
  3. Pandigital Super Nova Front Facing Camera Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, remove the back cover of the device.
  4. Pandigital Super Nova Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Remove the three .11 mm screws that hold the battery in place.
    • Set aside.
  5. Pandigital Super Nova Front Facing Camera Replacement: paso 5, imagen 1 de 2 Pandigital Super Nova Front Facing Camera Replacement: paso 5, imagen 2 de 2
    • Unplug the battery and remove from device.
    • Avoid touching the motherboard as it is fragile.
  6. Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: paso 6, imagen 1 de 2 Pandigital Super Nova Front Facing Camera Replacement, Front Facing Camera: paso 6, imagen 2 de 2
    • Use a metal pry tool to separate the camera and the small clip that holds it in place.
    • Do NOT touch the MotherBoard with your bare hands. There is risk of short circuiting the device. Use nitrile gloves to prevent this.
  7. Pandigital Super Nova Front Facing Camera Replacement: paso 7, imagen 1 de 2 Pandigital Super Nova Front Facing Camera Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
Conclusión
sterling hannsz
Miembro Desde 10/10/16
267 Reputación
2 Guías creadas
Equipo
Texas Tech, Team 1-2, Bennett Fall 2016 Miembro de Texas Tech, Team 1-2, Bennett Fall 2016
TTU-BENNETT-F16S1G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 113
