Saltar al contenido principal
Panasonic VDR-D220 DVD Motherboard Replacement
Qué necesitas
  1. Panasonic VDR-D220 DVD Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Use your Phillips #0 screwdriver to remove the three 5mm screws on top of the camera.
    • Remove the metal bracket.
  2. Panasonic VDR-D220 DVD Motherboard Replacement: paso 2, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 2, imagen 2 de 2
    • Rotate the camera to show the bottom of the camera.
    • Remove the four 5mm screws on the bottom side of the camera with a Phillips #0 driver.
  3. Panasonic VDR-D220 DVD Motherboard Replacement: paso 3, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove one 5mm screw with your Phillips #0 screwdriver.
  4. Panasonic VDR-D220 DVD Motherboard Replacement: paso 4, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 4, imagen 2 de 2
    • Using a spudger pry the top-front part of the camera from the main body.
    • Slide the top portion of the camera forward revealing more 5mm screws.
    • Do not completely separate the two sections of the camera as there are still cable connections holding them together.
  5. Panasonic VDR-D220 DVD Motherboard Replacement: paso 5, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 5, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 5, imagen 3 de 3
    • Flip the camera on the right side.
    • Gently pull the front part away from the main body to expose the cable connections holding them together.
    • Do not pull too hard because of the ZIF connector.
    • Use your plastic opening tool to disconnect the connection point safely.
    • Press the tab with plastic opening tool and then pull the ZIF connector to detach.
  6. Panasonic VDR-D220 DVD Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the 5mm screw with your Phillips #0 screwdriver that was previously covered.
  7. Panasonic VDR-D220 DVD Motherboard Replacement: paso 7, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 7, imagen 2 de 2
    • Use your Phillips #0 screwdriver to remove the two 5mm screws on the battery base of the camera.
  8. Panasonic VDR-D220 DVD Motherboard Replacement: paso 8, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 8, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 8, imagen 3 de 3
    • Rotate the camera to the left side, where the side port is located.
    • Open the side port door.
  9. Panasonic VDR-D220 DVD Motherboard Replacement: paso 9, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 9, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove three 5mm screws inside the side port by using Phillips #0 screwdriver.
    • Take off this part of the camera.
  10. Panasonic VDR-D220 DVD Motherboard Replacement: paso 10, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 10, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 10, imagen 3 de 3
    • Rotate the camera to the battery side.
    • Gently pull the side of the camera apart with only your hands.
    • Do not pull too hard because of the ZIF connector cable.
    • Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
  11. Panasonic VDR-D220 DVD Motherboard Replacement: paso 11, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 11, imagen 2 de 2
    • Rotate the camera to show the left side.
    • Remove one 5mm screw on the side of the battery's base with your Phillips #0 screwdriver.
    • Take off the battery base from the camera.
  12. Panasonic VDR-D220 DVD Motherboard Replacement: paso 12, imagen 1 de 1
    • Disconnect another ribbon cable that runs from the motherboard to the bottom of the viewfinder with a plastic opening tool.
  13. Panasonic VDR-D220 DVD Motherboard Replacement: paso 13, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 13, imagen 2 de 2
    • On the bottom side of the camera, remove six 5mm screws with your Phillips #0 screwdriver and the circuit board holder should be free.
  14. Panasonic VDR-D220 DVD Motherboard Replacement: paso 14, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 14, imagen 2 de 2
    • Insert a Jimmy tool to relieve the pressure between the metal mount and the plastic cover.
    • Take off the port board from the bottom of the camera.
  15. Panasonic VDR-D220 DVD Motherboard Replacement: paso 15, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 15, imagen 2 de 2
    • On the motherboard, remove two 5mm screws from the motherboard with your Phillips #0 screwdriver.
  16. Panasonic VDR-D220 DVD Motherboard Replacement: paso 16, imagen 1 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 16, imagen 2 de 3 Panasonic VDR-D220 DVD Motherboard Replacement: paso 16, imagen 3 de 3
    • Remove the remaining three ribbon connections with your plastic opening tool.
    • Once disconnected you will see that the motherboard now moves freely.
    • Rotate the motherboard out of the camera carefully.
    • Disconnect the ribbon cables smoothly and do not try to disconnect them with your hands.
    • Do not allow the ribbon cables to catch on anything, this will cuase them to rip and be unsusable.
  17. Panasonic VDR-D220 DVD Motherboard Replacement: paso 17, imagen 1 de 2 Panasonic VDR-D220 DVD Motherboard Replacement: paso 17, imagen 2 de 2
    • Slide the motherboard from the camera and it should come out smoothly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 202
