Qué necesitas
Remove all three 5mm screws from the top of the camera using a Phillips #0 screwdriver.
Rotate the camera to the battery side.
Gently pull the side of the camera apart with only your hands.
Disconnect the ribbon cable with your plastic opening tool, so that the left side of the camera can be removed.
Press the tab with plastic opening tool and then pull the ZIF connector to detach.
Casi Terminas!
Conclusión
