Saltar al contenido principal
Panasonic Toughbook CF-53 Battery Replacement
  1. Panasonic Toughbook CF-53 Battery Replacement, Battery: paso 1, imagen 1 de 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: paso 1, imagen 2 de 3 Panasonic Toughbook CF-53 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Orient the laptop on its side so that the plastic battery cover is facing upward.
    • Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
  2. Panasonic Toughbook CF-53 Battery Replacement: paso 2, imagen 1 de 2 Panasonic Toughbook CF-53 Battery Replacement: paso 2, imagen 2 de 2
    • Use the battery release slider to release the battery latch.
  3. Panasonic Toughbook CF-53 Battery Replacement: paso 3, imagen 1 de 3 Panasonic Toughbook CF-53 Battery Replacement: paso 3, imagen 2 de 3 Panasonic Toughbook CF-53 Battery Replacement: paso 3, imagen 3 de 3
    • Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
Conclusión
3 personas más completaron esta guía.
Un comentario
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
Rick Reeves - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 29
Ultimos 30 días: 111
Todo El Tiempo: 5,780
