Saltar al contenido principal
Panasonic Toughbook CF-29 Wireless Card Replacement
Qué necesitas
  1. Panasonic Toughbook CF-29 Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 2, imagen 1 de 2 Panasonic Toughbook CF-29 Wireless Card Replacement: paso 2, imagen 2 de 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Wireless Card Replacement, Back Cover: paso 3, imagen 1 de 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 6, imagen 1 de 2 Panasonic Toughbook CF-29 Wireless Card Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 7, imagen 1 de 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 8, imagen 1 de 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Wireless Card Replacement, Wireless Card: paso 9, imagen 1 de 1
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  10. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 10, imagen 1 de 1
    • Peel back the black cover to expose the clips holding in the wireless card.
  11. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 11, imagen 1 de 1
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  12. Panasonic Toughbook CF-29 Wireless Card Replacement: paso 12, imagen 1 de 2 Panasonic Toughbook CF-29 Wireless Card Replacement: paso 12, imagen 2 de 2
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
Conclusión
2 personas más completaron esta guía.
Devon Augustus
Miembro Desde 04/12/10
130 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 27-93, Amido Spring 2010 Miembro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
Miembros de 4
26 Guías creadas
Un comentario
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 14,863
