Saltar al contenido principal
Panasonic Toughbook CF-29 Speaker Replacement
Qué necesitas
  1. Panasonic Toughbook CF-29 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Speaker Replacement: paso 2, imagen 1 de 2 Panasonic Toughbook CF-29 Speaker Replacement: paso 2, imagen 2 de 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Speaker Replacement, Back Cover: paso 3, imagen 1 de 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Speaker Replacement: paso 5, imagen 1 de 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Speaker Replacement: paso 6, imagen 1 de 2 Panasonic Toughbook CF-29 Speaker Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Speaker Replacement: paso 7, imagen 1 de 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Speaker Replacement: paso 8, imagen 1 de 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Speaker Replacement, Speaker: paso 9, imagen 1 de 1
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
  10. Panasonic Toughbook CF-29 Speaker Replacement: paso 10, imagen 1 de 1
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
  11. Panasonic Toughbook CF-29 Speaker Replacement: paso 11, imagen 1 de 1
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
Conclusión
Rohun Heesen
Miembro Desde 04/13/10
426 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 27-93, Amido Spring 2010 Miembro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Miembros
26 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 5,366
