Saltar al contenido principal
Panasonic Toughbook CF-29 Heat Sink Replacement
Qué necesitas
  1. Panasonic Toughbook CF-29 Heat Sink Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 2, imagen 1 de 2 Panasonic Toughbook CF-29 Heat Sink Replacement: paso 2, imagen 2 de 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Heat Sink Replacement, Back Cover: paso 3, imagen 1 de 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 4, imagen 1 de 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 5, imagen 1 de 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 6, imagen 1 de 2 Panasonic Toughbook CF-29 Heat Sink Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 7, imagen 1 de 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 8, imagen 1 de 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Heat Sink Replacement, Heat Sink: paso 9, imagen 1 de 1
    • Locate the heat sink on the underside of the back cover.
    • It is the U shaped metallic piece.
  10. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 10, imagen 1 de 1
    • Remove the four screws with a Phillips size 1 screwdriver.
    • One on each of the ends
    • Two on the base of the U shape
  11. Panasonic Toughbook CF-29 Heat Sink Replacement: paso 11, imagen 1 de 1
    • Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
Conclusión
Una persona más ha completado esta guía.
Clint Kirsop
Miembro Desde 04/13/10
109 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 27-93, Amido Spring 2010 Miembro de Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 5,718
