Qué necesitas
Remove the three 6-mm screws on the hand-strap side of the camera.
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
Unscrew the two black 4 mm screws from metal casing around the motherboard.
Remove the black 4 mm screw located on the back of the camcorder under the SD card slot.
