Introducción
This guide will disassemble the device the most concise way possible to allow you to replace the Tape Player Cover.
Herramientas
Partes
No se especificaron partes.
Using a philips screwdriver, remove these eight 9.5 mm screws on the left and right sides of the device and place aside.
Use thumbs to push the casing forward as indicated.
Note the position of the tabs in these pictures. Once the casing has slid forward, it should come loose. Place it aside.
Casi Terminas!
Conclusión
