Saltar al contenido principal
Partes
No se especificaron partes.
  1. With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Now rotate the device 180 degrees and remove the second screw. Remove the screw that is on the right side of the panel facing you.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
  2. Rotate the device so that the back faces you. Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
  3. Before removing cover make sure that the back of the device is facing you.
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Pull up the two tabs on top Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you. Depress the four tabs on the bottom of the device with a flat head screwdriver.
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
  5. Carefully pull off the front panel of the device.
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Remove the four screws around the DVD drive with a phillips head screwdriver. Remove the four screws around the DVD drive with a phillips head screwdriver.
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
  7. The DVD player is attached to the power supply.
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
  8. Flip the DVD drive so that the bottom is facing you.
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
Conclusión
2 personas más completaron esta guía.
Nathan Cheadle
Miembro Desde 15/04/10
137 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 16-5, Maness Spring 2010 Miembro de Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,009
