Saltar al contenido principal
Panasonic RQ-2102 Holding Handle Replacement
Qué necesitas
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: paso 1, imagen 1 de 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: paso 1, imagen 2 de 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: paso 1, imagen 3 de 3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: paso 2, imagen 1 de 2 Panasonic RQ-2102 Holding Handle Replacement: paso 2, imagen 2 de 2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 588
