Saltar al contenido principal
Panasonic RQ-2102 Cassette Holder Spring Replacement
Qué necesitas
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: paso 1, imagen 1 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: paso 1, imagen 2 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: paso 1, imagen 3 de 3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: paso 2, imagen 1 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: paso 2, imagen 2 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: paso 2, imagen 3 de 3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: paso 3, imagen 1 de 2 Panasonic RQ-2102 Cassette Holder Spring Replacement: paso 3, imagen 2 de 2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 999
