Saltar al contenido principal
Panasonic RQ-2102 Buttons Replacement
Qué necesitas
  1. Panasonic RQ-2102 Buttons Replacement, Buttons: paso 1, imagen 1 de 3 Panasonic RQ-2102 Buttons Replacement, Buttons: paso 1, imagen 2 de 3 Panasonic RQ-2102 Buttons Replacement, Buttons: paso 1, imagen 3 de 3
    • Remove the three screws from the back of the device body.
    • Remove both screws from battery compartment.
    • Remove the back.
    • Make sure not to pull apart the cords that connect the device.
  2. Panasonic RQ-2102 Buttons Replacement: paso 2, imagen 1 de 3 Panasonic RQ-2102 Buttons Replacement: paso 2, imagen 2 de 3 Panasonic RQ-2102 Buttons Replacement: paso 2, imagen 3 de 3
    • Remove screws from the sides of the silver button pin roller.
    • Pry out the silver bar
    • Remove the desired button
  3. Panasonic RQ-2102 Buttons Replacement: paso 3, imagen 1 de 3 Panasonic RQ-2102 Buttons Replacement: paso 3, imagen 2 de 3 Panasonic RQ-2102 Buttons Replacement: paso 3, imagen 3 de 3
    • Insert the new button in place of the old button.
    • Put the silver pin roller back into its place over the buttons.
    • Put screws back into their original places by the sides of the silver pin roller.
    • If new buttons are not available, clean old buttons with a wet rag.
    • If the buttons do not work, ensure they are in their correct positions.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 805
