Saltar al contenido principal
Panasonic RQ-2102 Battery Replacement
Qué necesitas
  1. Panasonic RQ-2102 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Open the battery compartment by pressing down on the small tab along the upper edge of battery cover.
  2. Panasonic RQ-2102 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the old batteries one at a time.
    • If batteries do not come out or are rusted, remove carefully with a prying tool. If rusty or dirty, clean compartment and contacts with a dry towel.
  3. Panasonic RQ-2102 Battery Replacement: paso 3, imagen 1 de 2 Panasonic RQ-2102 Battery Replacement: paso 3, imagen 2 de 2
    • Insert the new working batteries in the order listed in the diagram on the back of the device.
    • Both batteries in a single row should be facing the same direction and make contact + to -.
  4. Panasonic RQ-2102 Battery Replacement: paso 4, imagen 1 de 1
    • Put the battery cover back onto the device.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 908
