Saltar al contenido principal
Panasonic Lumix ZS50 Battery Replacement
Qué necesitas
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: paso 1, imagen 1 de 2 Panasonic Lumix ZS50 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: paso 2, imagen 1 de 2 Panasonic Lumix ZS50 Battery Replacement: paso 2, imagen 2 de 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: paso 3, imagen 1 de 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: paso 4, imagen 1 de 1
    • The battery should now be released; you may now remove the battery from the camera body.
Conclusión
Una persona más ha completado esta guía.
Cameron Voos
Miembro Desde 02/01/17
32 Reputación
1 Guía escrita
Equipo
Baylor, Team 8-5, Whitney Spring 2017 Miembro de Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Miembros
4 Guías creadas
Un comentario
Repair guide is very clear and well-done
BayleeVersteeg - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 472
