Saltar al contenido principal
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: paso 1, imagen 3 de 3
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 2, imagen 3 de 3
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 3, imagen 1 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 3, imagen 2 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 3, imagen 3 de 3
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: paso 4, imagen 3 de 3
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Conclusión
Trevor Meyers
Miembro Desde 03/03/15
356 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 250
