Partes
  1. Remove Battery and Strap from unit. Remove the 3 screws from the bottom Remove screws from both sides of unit (4 screws total)
    • Remove Battery and Strap from unit.
    • Remove the 3 screws from the bottom
    • Remove screws from both sides of unit (4 screws total)
  2. Remove both side panels from unit. You can pry them off with your finger nail or a spudger Remove both side panels from unit. You can pry them off with your finger nail or a spudger
    • Remove both side panels from unit. You can pry them off with your finger nail or a spudger
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Pry off rear cover. Make sure LCD remains in place. There is a thin film of adhesive attaching the LCD to the rear cover.  It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover.
    • Pry off rear cover. Make sure LCD remains in place.
    • There is a thin film of adhesive attaching the LCD to the rear cover. It releases easily with a little pressure. If necessary hold the LCD in place while removing the rear cover.
  5. Release the Ziff clamp holding the LCD cable. 1st photo shows clamp in closed position. You can use a spudger to release the clamp. You can also use your finger nail, but be careful it is very fragile. Remove the LCD Flex from the clamp
    • Release the Ziff clamp holding the LCD cable. 1st photo shows clamp in closed position.
    • You can use a spudger to release the clamp. You can also use your finger nail, but be careful it is very fragile.
    • Remove the LCD Flex from the clamp
  6. You may need to pry off the window plate of your old screen if the new screen doesn't have one. If required: Remove the window plate from your old screen if your new LCD doesn't have one.  Save this part for re-install. If required: Remove the window plate from your old screen if your new LCD doesn't have one.  Save this part for re-install.
    • You may need to pry off the window plate of your old screen if the new screen doesn't have one.
    • If required: Remove the window plate from your old screen if your new LCD doesn't have one. Save this part for re-install.
  7. If your new LCD does not come with a window plate:  Tape your old window plate in place as shown in the photo. Make sure it lines up properly and fits into the grooves.  This makes re-assembly much easier. If necessary clean the window plate and LCD with a micro fiber dry cloth. Make sure there is no debris or dust before you re-install.  DO NOT use any liquids.
    • If your new LCD does not come with a window plate: Tape your old window plate in place as shown in the photo. Make sure it lines up properly and fits into the grooves. This makes re-assembly much easier.
    • If necessary clean the window plate and LCD with a micro fiber dry cloth. Make sure there is no debris or dust before you re-install. DO NOT use any liquids.
    • Now just reverse the steps to re-assemble your camera with the new screen.
Conclusión
Sales Cameraparts4you
Miembro Desde 01/07/16
2,479 Reputación
20 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 39
