Saltar al contenido principal
Panasonic Lumix DMC-ZS60 LCD Screen Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: paso 4, imagen 3 de 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 7, imagen 3 de 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 8, imagen 1 de 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: paso 8, imagen 2 de 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 33
Todo El Tiempo: 734
