Saltar al contenido principal
Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 2, imagen 2 de 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 3, imagen 1 de 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: paso 4, imagen 3 de 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 5, imagen 1 de 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 6, imagen 2 de 2
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 7, imagen 3 de 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 8, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 8, imagen 2 de 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: paso 9, imagen 1 de 1
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 10, imagen 1 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 10, imagen 2 de 3 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 10, imagen 3 de 3
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 11, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 11, imagen 2 de 2
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: paso 12, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: paso 12, imagen 2 de 2
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 13, imagen 1 de 2 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: paso 13, imagen 2 de 2
    • Lift the camera lens from the camera.
Conclusión
Una persona más ha completado esta guía.
Un comentario
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 47
Todo El Tiempo: 2,227
