Saltar al contenido principal
Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: paso 1, imagen 1 de 1
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 2, imagen 3 de 3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 3, imagen 1 de 1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 4, imagen 2 de 2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: paso 5, imagen 1 de 1
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Conclusión
Derrick Thompson
Miembro Desde 01/30/18
1,035 Reputación
5 Guías creadas
Equipo
Baylor, Team S2-G5, Johnson Spring 2018 Miembro de Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 224
