Saltar al contenido principal
Panasonic Lumix DMC-ZS6 Flash Assembly Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 1 de 1
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 2, imagen 3 de 3
    • Unscrew the two 1.0 mm screws on the bottom with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 3, imagen 1 de 1
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 4, imagen 2 de 2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 5, imagen 1 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 5, imagen 2 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 5, imagen 3 de 3
    • Unscrew the 1.0 mm screws to the left with Phillips #000 screwdriver.
    • Unscrew the 1.0 mm screws to the right with Phillips #000 screwdriver.
    • Unscrew the one bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 6, imagen 1 de 1
    • Separate the front of the camera from the main body carefully.
  7. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 7, imagen 1 de 2 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 7, imagen 2 de 2
    • Use the tip of the spudger to disengage the plastic tab.
    • Lift the selector switch away from the motherboard carefully.
  8. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 8, imagen 1 de 2 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 8, imagen 2 de 2
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab, then carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 9, imagen 1 de 1
    • Insert the tip of the spudger into the center hole of the tripod mount, and apply force in the direction facing away from the button.
    • Lift the tripod mount out of the camera body carefully.
  10. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 10, imagen 1 de 2 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 10, imagen 2 de 2
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard, then apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 11, imagen 1 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 11, imagen 2 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 11, imagen 3 de 3
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phlllips #000 screwdriver to remove the three silver 1.0 mm screws.
    • Lift the lens assembly out of the camera carefully.
  12. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 12, imagen 1 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 12, imagen 2 de 3 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 12, imagen 3 de 3
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Lift the top assembly out of place carefully.
  13. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 13, imagen 1 de 2 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: paso 13, imagen 2 de 2
    • Use the spudger to disengage the two tabs.
    • Lift the flash assembly out of place carefully.
Conclusión
Derrick Thompson
Miembro Desde 01/30/18
1,035 Reputación
5 Guías creadas
Equipo
Baylor, Team S2-G5, Johnson Spring 2018 Miembro de Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 153
