Saltar al contenido principal
Panasonic Lumix DMC-ZS40 Motherboard Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS40 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 2, imagen 1 de 1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Motherboard Replacement, LCD Screen: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement, LCD Screen: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement, LCD Screen: paso 4, imagen 3 de 3
    • Unscrew the five 3mm screws located around the sides of the camera using a PH000 bit or Phillips 000 Screwdriver.
  5. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 5, imagen 2 de 2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 6, imagen 1 de 1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 7, imagen 3 de 3
    • Turn the LCD screen over to the side exposing the connection to the motherboard.
    • Remove the display data cable connecting the LCD screen to the motherboard. Using tweezers, pry up the black retaining flap then gently pull the display data cable free.
    • Be careful when handling any display data cables in the camera as they are prone to tearing.
    • To close for reassembly, slide the display data cable back into the ZIF connector and close the retaining flap.
  8. Panasonic Lumix DMC-ZS40 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Disconnect the control dial from the motherboard. Locate the ZIF connector for the control dial. Use tweezers or screwdrivers to lift up on the retaining flap to remove the ribbon cable.
    • The connector ribbons are prone to tearing so use care during removal.
  9. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 9, imagen 1 de 1
    • Pry the HDMI cover off the side of the camera.
    • No tools are required for this step.
  10. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 10, imagen 1 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 10, imagen 2 de 3 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove these four 4mm on the top of the plate cover and the 3mm screw on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  11. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 11, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 11, imagen 2 de 2
    • Pry the black cover shielding the ZIF connectors off with your hand.
  12. Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 12, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Motherboard Replacement: paso 12, imagen 2 de 2
    • Disconnect these 6 ribbon cables from the motherboard. Use tweezers or a screw driver to lift up on the retaining flaps for each ZIF connector.
Conclusión
Una persona más ha completado esta guía.
Kevin Tran
Miembro Desde 02/14/17
215 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 20-3, Remmell Spring 2017 Miembro de USF Tampa, Team 20-3, Remmell Spring 2017
USFT-REMMELL-S17S20G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 605
