Saltar al contenido principal
Panasonic Lumix DMC-ZS40 Camera Sensor Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: paso 1, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Battery: paso 1, imagen 2 de 2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 2, imagen 1 de 1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 3, imagen 2 de 2
    • Remove battery from camera.
  4. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement, Camera Sensor: paso 4, imagen 3 de 3
    • Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
  5. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 5, imagen 2 de 2
    • Pry off the back casing of the camera and place the camera face down.
  6. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 6, imagen 1 de 1
    • Flip the right hand side control dial circuit board up.
  7. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 7, imagen 3 de 3
    • Place the LCD screen to the side while you remove the plate cover. The LCD has already been removed in this picture. It is not necessary to remove the LCD screen or the control dial for this guide.
    • Remove these four 4mm screws and the 3mm screw on the top of the plate cover and on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
    • Keep track of the different screw lengths and do not mix them up.
  8. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 8, imagen 1 de 1
    • Remove the ribbon cable connecting the sensor to the motherboard. Use tweezers or a screw driver to lift up on the retaining flap of the ZIF connector to remove the cable.
  9. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 9, imagen 1 de 1
    • Using the T3 Phillips Screwdriver, unscrew the three Torx T3 2.5mm screws holding the sensor down.
  10. Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 10, imagen 1 de 2 Panasonic Lumix DMC-ZS40 Camera Sensor Replacement: paso 10, imagen 2 de 2
    • Gently lift the sensor off of the springs.
Conclusión
Una persona más ha completado esta guía.
Dean Favetta
Miembro Desde 02/14/17
340 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 20-3, Remmell Spring 2017 Miembro de USF Tampa, Team 20-3, Remmell Spring 2017
USFT-REMMELL-S17S20G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 861
