Saltar al contenido principal
Panasonic Lumix DMC-ZS35 Lens Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS35 Lens Replacement, Back Casing: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement, Back Casing: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement, Back Casing: paso 1, imagen 3 de 3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS35 Lens Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 3, imagen 1 de 1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
  4. Panasonic Lumix DMC-ZS35 Lens Replacement, Screen: paso 4, imagen 1 de 2 Panasonic Lumix DMC-ZS35 Lens Replacement, Screen: paso 4, imagen 2 de 2
    • Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
  5. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 5, imagen 1 de 1
    • Gently pull LCD screen ribbon cable from internal port to disconnect the screen and prevent unwanted damage.
    • Lift the freed LCD screen from the base camera to complete the process.
  6. Panasonic Lumix DMC-ZS35 Lens Replacement, Lens: paso 6, imagen 1 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement, Lens: paso 6, imagen 2 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement, Lens: paso 6, imagen 3 de 3
    • Remove the four 2mm Phillips #000 screws on the sides of the exposed internal metal plate within the camera.
  7. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS35 Lens Replacement: paso 7, imagen 3 de 3
    • Using an iFixit opening tool, gently remove the plating.
    • Carefully remove the ribbon cable connecting the plating with the lens component.
  8. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 8, imagen 1 de 2 Panasonic Lumix DMC-ZS35 Lens Replacement: paso 8, imagen 2 de 2
    • Remove the 2mm screws holding the lens in place with a Phillips #000 screwdriver, located along the perimeter of the lens component within its housing.
  9. Panasonic Lumix DMC-ZS35 Lens Replacement: paso 9, imagen 1 de 2 Panasonic Lumix DMC-ZS35 Lens Replacement: paso 9, imagen 2 de 2
    • Carefully lift the lens component from the housing once it is freed.
    • Ensure that all connectors and cables are disconnected between the lens and other components before separation.
Conclusión
Rachel Hughes
Miembro Desde 01/31/20
688 Reputación
4 Guías creadas
Equipo
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G2, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 439
