Saltar al contenido principal
Panasonic Lumix DMC-ZS35 LCD Screen Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Back Casing: paso 1, imagen 3 de 3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS35 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
  4. Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Screen: paso 4, imagen 1 de 2 Panasonic Lumix DMC-ZS35 LCD Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Unscrew the four 3mm screws holding the LCD screen hinge in place using a Phillips #000 screwdriver.
  5. Panasonic Lumix DMC-ZS35 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Gently pull LCD screen ribbon cable from internal port to disconnect the screen and prevent unwanted damage.
    • Lift the freed LCD screen from the base camera to complete the process.
Conclusión
Rachel Hughes
Miembro Desde 01/31/20
688 Reputación
4 Guías creadas
Equipo
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G2, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 552
