Introducción
If your Lumix’s flash isn’t functioning, is broken, not performing as intended, or so on, it might be the result of a broken flash bulb within your Lumix. By following this guide, you’ll be able to remove and replace your flash component to your Lumix.
Before you replace your flash, take a look at this Troubleshooting Guide to see if there is a simpler solution to your problem. Before beginning, make sure to turn off your camera completely and remove its battery.
Qué necesitas
Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
Unscrew the six 3mm screws holding the LCD screen hinge in place using a Phillips 000 screwdriver.
Gently pull LCD screen ribbon cable from the internal port to disconnect the screen and prevent unwanted damage.
Lift the freed LCD screen from the base of the camera to complete the process.
Face the front of the camera away from you, and remove the 3mm screw in the upper left corner with a Phillips #000 screwdriver.
Now that you have removed all of the screws holding it down, the entire top panel will be loose. Wiggle it with your fingers until you are able to completely remove it.
Remove the 3mm screw that is tucked behind the flash with a Phillips #000 screwdriver. It is a little tricky to see, but your screwdriver should be able to fit between the crack.
Una persona más ha completado esta guía.
