Saltar al contenido principal
Panasonic Lumix DMC-ZS35 Back Casing Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS35 Back Casing Replacement, Back Casing: paso 1, imagen 3 de 3
    • Remove the six 4mm screws located on the side and bottom of the camera casing using a Phillips #000 screwdriver.
  2. Panasonic Lumix DMC-ZS35 Back Casing Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS35 Back Casing Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to carefully separate the back casing from the main body of the camera. It's advised to run along the entire "seam" of the casing and the camera with the tool to ensure full separation.
  3. Panasonic Lumix DMC-ZS35 Back Casing Replacement: paso 3, imagen 1 de 1
    • Gently pry apart the back casing from the body of the camera. It's recommended to apply as minimal force as is necessary to prevent unintended damage to the camera or the casing.
Conclusión
John Schug
Miembro Desde 02/04/20
97 Reputación
1 Guía escrita
Equipo
UW Stout, Team S1-G2, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G2, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 152
