Saltar al contenido principal
Panasonic Lumix DMC-ZS3 Lens Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 2, imagen 2 de 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 3, imagen 2 de 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: paso 4, imagen 1 de 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: paso 5, imagen 1 de 1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: paso 6, imagen 1 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 6, imagen 2 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 6, imagen 3 de 3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-ZS3 Lens Replacement: paso 7, imagen 3 de 3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
Conclusión
Kellen Ericson
Miembro Desde 04/17/13
18 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-60, Johann Spring 2013 Miembro de Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 3,312
