Introducción
These steps will guide to simply replace your camera's screen.
Qué necesitas
Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
Remove the two 2.60 mm screws located next to the battery.
3 personas más completaron esta guía.
Un comentario
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
