Saltar al contenido principal
Panasonic Lumix DMC-ZS25 Power Button Replacement
Qué necesitas
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: paso 1, imagen 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: paso 1, imagen 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: paso 1, imagen 3 de 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 3, imagen 2 de 2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 4, imagen 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 4, imagen 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 4, imagen 3 de 3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 5, imagen 2 de 2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 6, imagen 2 de 2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 7, imagen 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 7, imagen 2 de 2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 8, imagen 1 de 1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 9, imagen 1 de 1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 10, imagen 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 10, imagen 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: paso 10, imagen 3 de 3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Conclusión
Una persona más ha completado esta guía.
Abbas Khan
Miembro Desde 01/21/15
482 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 9-5, Brown Winter 2015 Miembro de USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 8
Todo El Tiempo: 578
