Saltar al contenido principal
Panasonic Lumix DMC-GX85 Main PCB Replacement
Qué necesitas
  1. Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: paso 1, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: paso 1, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement, Rear Cover: paso 1, imagen 3 de 3
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 2, imagen 3 de 3
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 3, imagen 2 de 2
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 4, imagen 2 de 2
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 5, imagen 2 de 2
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 6, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 6, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 6, imagen 3 de 3
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 7, imagen 3 de 3
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
  8. Panasonic Lumix DMC-GX85 Main PCB Replacement, Main PCB: paso 8, imagen 1 de 2 Panasonic Lumix DMC-GX85 Main PCB Replacement, Main PCB: paso 8, imagen 2 de 2
    • Remove the three 3.5mm silver Phillips #0 screws mounting the main PCB to the camera frame.
  9. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 9, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 9, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 9, imagen 3 de 3
    • Disconnect the eight ribbon cables from the main PCB by pulling up on the black locking tabs with an iFixit opening tool.
    • Pull the ribbon cables from the connectors.
  10. Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 10, imagen 1 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 10, imagen 2 de 3 Panasonic Lumix DMC-GX85 Main PCB Replacement: paso 10, imagen 3 de 3
    • Gently lift the motherboard away from the camera body.
    • When removing the main PCB, take care not to lose the battery earth plate.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Good day. How do I get the board both of the, the one on the right and one on d left
Tobas - Contestar
Where i can find this replacement ? DMC-GX85 Main PCB Replacement
vissente tapia cuevas - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 26
Ultimos 30 días: 94
Todo El Tiempo: 2,621
