Introducción
The proximity sensor, or eye sensor, is used to tell the Panasonic Lumix DMC-GX85 when to activate the viewfinder when you put your eye up to it. If this is not happening when you hold the camera up to your eye, you may need to replace this sensor.
Qué necesitas
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
Remove the 4.5mm black Phillips #0 screw under the viewfinder.
Gently pull the viewfinder cover from the camera.
Hold the viewfinder with the ribbon cables facing up and towards you.
Remove the black 4.5mm screw Phillips screw from the bottom of the viewfinder.
