Saltar al contenido principal
Panasonic Lumix DMC-GF2 LCD Replacement
Qué necesitas
  1. Panasonic Lumix DMC-GF2 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 LCD Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-GF2 LCD Replacement: paso 2, imagen 2 de 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: paso 3, imagen 1 de 3 Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: paso 3, imagen 2 de 3 Panasonic Lumix DMC-GF2 LCD Replacement, Back Cover: paso 3, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 LCD Replacement: paso 4, imagen 1 de 3 Panasonic Lumix DMC-GF2 LCD Replacement: paso 4, imagen 2 de 3 Panasonic Lumix DMC-GF2 LCD Replacement: paso 4, imagen 3 de 3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 LCD Replacement: paso 5, imagen 1 de 1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 LCD Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 LCD Replacement: paso 7, imagen 1 de 1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 LCD Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 LCD Replacement: paso 9, imagen 1 de 1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
  10. Panasonic Lumix DMC-GF2 LCD Replacement, LCD screen: paso 10, imagen 1 de 1
    • Using your fingers, push down on the small, metal hooks that are a part of the metal cover and attach on top of the LCD screen.
  11. Panasonic Lumix DMC-GF2 LCD Replacement: paso 11, imagen 1 de 1
    • Using your fingers, remove the LCD screen from the metal cover. This may require some back and forth movements of the LCD screen until it detaches completely from the bottom hooks.
    • Careful not to rip the yellow ribbons when removing the LCD screen from the metal cover.
Conclusión
4 personas más completaron esta guía.
Kingsley East
Miembro Desde 10/30/16
462 Reputación
4 Guías creadas
Equipo
Baylor, Team 5-9, Williams Fall 2016 Miembro de Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Miembros
11 Guías creadas
2 comentarios
In Step 3 above, you definitely need to remove the hot shoe cover, and the 4 screws underneath that in order to remove the back of the camera safely! If you don’t, the back cover only comes off with excessive force and then causes damage to the portion of the bracket holding it in place beneath the hot shoe - trust me, I know from experience.
karl - Contestar
after removing the hot shoe cover i cannot see the screws you are talking about. I have undone the 6 screws mentioned in the guide, but the back of the camera still does not want to come off. I don't want to force it, but i can't see any more screws holding it in. can anyone help?
fasta rasta -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 46
Todo El Tiempo: 2,903
