Saltar al contenido principal
Panasonic Lumix DMC-GF2 Front Cover Replacement
Qué necesitas
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-GF2 Front Cover Replacement: paso 2, imagen 2 de 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: paso 3, imagen 1 de 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: paso 3, imagen 2 de 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: paso 3, imagen 3 de 3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: paso 5, imagen 1 de 1
    • Using your hand, gently lift up the front cover and separate it from the camera.
Conclusión
Nicole Gerlach
Miembro Desde 10/30/16
218 Reputación
1 Guía escrita
Equipo
Baylor, Team 5-9, Williams Fall 2016 Miembro de Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 19
Todo El Tiempo: 993
