Introducción
If rotating the rear thumbwheel elicits no or inconsistent response from a powered on camera, it may need replacement. Follow this guide to learn how to remove and replace the rear thumbwheel.
Qué necesitas
Unlock and open the battery compartment on the bottom of the camera.
Remove both the battery and SD card.
Remove the 4 indicated red 3.0mm long screws from the corners of mainboard using a Phillips PH0 screwdriver.
With the eyepiece facing away from you, pull up on the main PCB from the left side and then pull it away from the chassis.
There is a plastic locking tab on the bottom of the camera that holds the mainboard PCB.
Remove the three indicated red 3.0mm screws from heat sink shield using a Phillips PH0 screwdriver, then remove the heat sink.
3 personas más completaron esta guía.
