Saltar al contenido principal
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
Qué necesitas
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: paso 1, imagen 1 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: paso 1, imagen 2 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: paso 1, imagen 3 de 3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 2, imagen 3 de 3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 3, imagen 1 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 3, imagen 2 de 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 3, imagen 3 de 3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 4, imagen 2 de 2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: paso 5, imagen 2 de 2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-3, Kass Spring 2017 Miembro de USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,021
