Saltar al contenido principal
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: paso 1, imagen 1 de 1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 4, imagen 2 de 2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 5, imagen 2 de 2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: paso 6, imagen 2 de 2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 290
