Saltar al contenido principal
Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: paso 1, imagen 1 de 1
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 2, imagen 1 de 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 2, imagen 2 de 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 2, imagen 3 de 3
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 3, imagen 1 de 1
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 4, imagen 1 de 1
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 5, imagen 2 de 2
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 6, imagen 2 de 2
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: paso 7, imagen 3 de 3
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 344
