Saltar al contenido principal
Panasonic Lumix DMC-FX37 Lens Casing Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX37 Lens Casing Replacement, Panasonic Lumix DMC-FX37 Disassembly: paso 1, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement, Panasonic Lumix DMC-FX37 Disassembly: paso 1, imagen 2 de 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 2, imagen 2 de 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 3, imagen 2 de 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 4, imagen 1 de 3 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 4, imagen 2 de 3 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 4, imagen 3 de 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 5, imagen 1 de 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 Lens Casing Replacement, Lens Casing: paso 6, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement, Lens Casing: paso 6, imagen 2 de 2
    • Unscrew the silver 2mm screw from the protection panel.
    • Unscrew the three black 8mm screws from the protection panel.
    • Be sure to remember where these screws go, inserting a longer screw in a short slot can damage your device!
    • Remove the protection panel entirely.
  7. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 7, imagen 1 de 1
    • Insert the flat end of a spudger underneath the motherboard and twist. This will disconnect it from the rest of the device.
  8. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 8, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 8, imagen 2 de 2
    • Using the pointed end of a spudger, flip up the two black tabs holding the ribbon cables in place.
  9. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 9, imagen 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 9, imagen 2 de 2
    • Unscrew the three 3mm screws holding the photoreceptor in place.
    • Lift the photoreceptor and gently pull it to release the now disconnected ribbon cable.
  10. Panasonic Lumix DMC-FX37 Lens Casing Replacement: paso 10, imagen 1 de 1
    • Gently lift and remove the lens casing, pulling it free from the now disconnected ribbon cable.
Conclusión
Ben DuBose
Miembro Desde 01/30/18
327 Reputación
3 Guías creadas
Equipo
Baylor, Team S2-G3, Johnson Spring 2018 Miembro de Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 27
Todo El Tiempo: 460
