Saltar al contenido principal
Panasonic Lumix DMC-FX07 LCD Display Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX07 LCD Display Replacement, Battery: paso 1, imagen 1 de 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 2, imagen 2 de 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 LCD Display Replacement, Memory Card: paso 3, imagen 1 de 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 LCD Display Replacement, Back Cover: paso 4, imagen 1 de 2 Panasonic Lumix DMC-FX07 LCD Display Replacement, Back Cover: paso 4, imagen 2 de 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 5, imagen 2 de 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 6, imagen 1 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 6, imagen 2 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 6, imagen 3 de 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement: paso 7, imagen 3 de 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: paso 8, imagen 1 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: paso 8, imagen 2 de 3 Panasonic Lumix DMC-FX07 LCD Display Replacement, LCD Display: paso 8, imagen 3 de 3
    • Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out.
Conclusión
James Cruz
Miembro Desde 04/14/12
6 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-23, Amido Spring 2012 Miembro de Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 28
Todo El Tiempo: 2,020
