Saltar al contenido principal
Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: paso 1, imagen 1 de 1
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 2, imagen 1 de 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 2, imagen 2 de 2
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: paso 3, imagen 1 de 1
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: paso 4, imagen 1 de 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: paso 4, imagen 2 de 2
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 5, imagen 1 de 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 5, imagen 2 de 2
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 6, imagen 1 de 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 6, imagen 2 de 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 6, imagen 3 de 3
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 7, imagen 1 de 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 7, imagen 2 de 3 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: paso 7, imagen 3 de 3
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: paso 8, imagen 1 de 2 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: paso 8, imagen 2 de 2
    • Gently wiggle out the top motherboard.
    • The buttons are hardwired into this logic board.
Conclusión
Una persona más ha completado esta guía.
Karissa
Miembro Desde 04/13/12
50 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-23, Amido Spring 2012 Miembro de Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 895
