Herramientas
Partes
No se especificaron partes.
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
Use this screwdriver for all screws in the device.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Carefully remove the upper assembly, which houses the buttons and the flash battery.
2 personas más completaron esta guía.
Un Comentario
Olá ! Sugiro ter cuidado com a carga do capacitor do flash, melhor descarrega-lo com auxílio de uma lâmpada ou resistor
para evitar um choque elétrico.
