Saltar al contenido principal
Panasonic Lumix DMC-FX01 Camera Lens Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 2, imagen 1 de 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: paso 4, imagen 1 de 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 5, imagen 1 de 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 6, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 6, imagen 2 de 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 7, imagen 1 de 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 8, imagen 1 de 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 9, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 9, imagen 2 de 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: paso 10, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: paso 10, imagen 2 de 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  11. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 11, imagen 1 de 3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 11, imagen 2 de 3 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 11, imagen 3 de 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  12. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 12, imagen 1 de 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  13. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: paso 13, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: paso 13, imagen 2 de 2
    • Remove the three black 5mm screws attached to the lens frame.
  14. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 14, imagen 1 de 1
    • Remove the lens frame.
  15. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 15, imagen 1 de 1
    • Lift out the circuit board as shown.
  16. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 16, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 16, imagen 2 de 2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  17. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 17, imagen 1 de 1
    • Remove the lens assembly as shown.
  18. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: paso 18, imagen 1 de 1
    • Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
  19. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 19, imagen 1 de 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 19, imagen 2 de 2
    • Separate the fixed frame unit from the main lens assembly.
    • Separate the direct frame unit from the main lens assembly.
  20. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 20, imagen 1 de 1
    • Remove the first lens frame from the lens assembly.
  21. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 21, imagen 1 de 1
    • Detach the second frame unit from the lens assembly.
  22. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 22, imagen 1 de 1
    • Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
  23. Panasonic Lumix DMC-FX01 Camera Lens Replacement: paso 23, imagen 1 de 1
    • Separate the lens housing.
    • Replace the lens by gently prying away from the assembly.
Conclusión
4 personas más completaron esta guía.
Caleb Fink
Miembro Desde 10/11/10
191 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-22, Regan Fall 2010 Miembro de Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 12,743
