Saltar al contenido principal
Panasonic Lumix DMC-FH20 LCD Screen Replacement
Qué necesitas
  1. Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 3, imagen 1 de 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
  4. Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 4, imagen 1 de 2 Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the white plastic cover. This may take some extra force. You will want to try to remove from the bottom side first and peel up.
    • Then, where the silver switch is located, it will slide directly out at the top.
  5. Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Unscrew one screw (Phillips #000 head).
  6. Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 6, imagen 1 de 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 6, imagen 2 de 3 Panasonic Lumix DMC-FH20 LCD Screen Replacement: paso 6, imagen 3 de 3
    • You will want to use a plastic opening tool to complete this step. Pop the thin black piece of plastic upwards with the opening tool to unlock the plastic film ribbon.
    • Once unlocked, you will be able to pull the ribbon out and remove the screen completely.
Conclusión
Una persona más ha completado esta guía.
Arianna Boushell
Miembro Desde 01/24/17
626 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 10-7, Banghart Winter 2017 Miembro de Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 584
