Saltar al contenido principal
Panasonic Lumix DMC-F7 Fixing the Lens Apparatus
Qué necesitas
  1. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus, Battery: paso 1, imagen 1 de 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 2, imagen 1 de 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus, Back Case: paso 3, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 4, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 5, imagen 1 de 1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 6, imagen 1 de 2 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 6, imagen 2 de 2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 7, imagen 1 de 2 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 7, imagen 2 de 2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 8, imagen 1 de 1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus, Front Case: paso 9, imagen 1 de 1
    • Remove the last two 2.8 mm Phillips #00 screws from the bottom of the camera.
  10. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 10, imagen 1 de 3 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 10, imagen 2 de 3 Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 10, imagen 3 de 3
    • Using the spudger, pry the front case away from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful to ensure that internal materials won't be caught.
    • Separate the front of the case from the camera.
    • To reinstall the front case, solder the wires of the new case to the components of the camera.
  11. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus, Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 11, imagen 1 de 1
    • Check the "V" shaped spring to see if it is connected to the body of the camera.
  12. Panasonic Lumix DMC-F7 Fixing the Lens Apparatus: paso 12, imagen 1 de 1
    • Manually move the lens apparatus on the inside to shown position.
    • Ensure the spring is aligned correctly so that the lens opens.
    • If the lens does not open, remove the spring and place it in its proper position.
    • If the spring is defective, purchase a new spring.
Conclusión
Una persona más ha completado esta guía.
Alex Penman
Miembro Desde 01/28/11
463 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-35, Regan Winter 2011 Miembro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,435
