Introducción
Fixing the lens apparatus on your camera.
Partes
No se requieren partes.
  1. Slide the lock into the unlocked position to the right.
    • Slide the lock into the unlocked position to the right.
    • Use your finger to slide battery hatch towards the arrow sign.
    • Both battery and memory card should now be visible.
  2. Open battery hatch and the black cover to expose the battery compartment.
    • Open battery hatch and the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Pull the battery out and replace with a new one.
    • When putting the battery back in, make sure it is in the same orientation as before.
    • Close the battery compartment, and make sure the lock is in the locked position.
  3. Remove the two 2.8 mm Phillips screws as shown in picture.
    • Remove the two 2.8 mm Phillips screws as shown in picture.
  4. Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
    • Using a Philips Screw Driver, remove the three 2.8 mm Phillips screws on the bottom of the camera as shown in picture.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
    • Remove the two 2.8 mm Phillips screws on the side of the camera as shown in picture.
  7. Use a spudger to pry open the case from all sides. Use a spudger to pry open the case from all sides.
    • Use a spudger to pry open the case from all sides.
  8. Beware of the ribbon cable that is still attached when opening. Use your fingers to carefully pry off the back casing from the camera assembly.
    • Beware of the ribbon cable that is still attached when opening.
    • Use your fingers to carefully pry off the back casing from the camera assembly.
  9. Lay the camera on its front side./combine this sentence to the step below.
    • Lay the camera on its front side./combine this sentence to the step below.
    • Use Spudger tool to open the film strip locking mechanism and remove strip./No edits necessary.
    • Hold down on the camera's metal casing with one hand. Using your other hand, completely lift the back case off the rest of the camera, making sure the film strip separates./Make a picture for this step.
  10. Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
    • Remove the two remaining 2.8 mm Phillips screws on the bottom of the camera.
    • The other three screws shown in picture were removed to take off the back case.
  11. Using Spudger tool, pry the front case from the camera's components. Use your fingers to carefully pull the back case from the front case. Cut the black and red wires connecting front case to the body of the camera.
    • Using Spudger tool, pry the front case from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful nothing gets caught, and separate the front case from the camera.
    • To put the new front case back on, solder the wires of the new front case to the components of the camera.
  12. Check the "V" shaped spring to see if it is connected.
    • Check the "V" shaped spring to see if it is connected.
  13. Manually move the lens apparatus from the inside to shown position.
    • Manually move the lens apparatus from the inside to shown position.
    • Check to see if the spring is aligned correctly and the lens opens.
    • If not, you will need to take out the spring and place it into the proper position, or get a new spring all together.
Conclusión
Una persona más ha completado esta guía.
Alex Penman
Miembro Desde 28/01/11
463 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-35, Regan Winter 2011 Miembro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,176
