Saltar al contenido principal
Panasonic Lumix DMC-F7 Battery Replacement
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: paso 2, imagen 1 de 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 7-35, Regan Winter 2011 Miembro de Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 2,336
