Introducción
Is your camera still not turning on even with a working battery? Are your pictures not storing properly? Is your screen working, but still not displaying pictures? These problems may be due to a broken or faulty motherboard.
Qué necesitas
Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
Use a Phillips #000 screwdriver to remove the five 4.5 mm screws located on the bottom of the camera and the top one on the left side, with the lens facing you.
Use a Phillips #000 screwdriver to remove the two 3.5 mm screws, one below the lens and one on the left side.
Use a Phillips #000 screwdriver to remove the 7.1 mm screw from the right side of the camera.
Herramienta utilizada en este paso:Tweezers$4.99
Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector.
Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables.
3 personas más completaron esta guía.
2 comentarios
This camera is a true dust harvester.
Thanks to this guide I have dared to clean the sensor successfully.
I know that I will have to return to the task in a few months but now I am more sure of the process.
Thanks a lot
Just a quick question! After replacing the motherboard, the camera works just fine or is it needed a software intervention?
